Amazing Deep Flower-Leaves Mandala in a Round Coaster
Made by Robert Danforth
This design is full 3D that if cut as variable power will go from highest in the middle to lowest beyond the last leaf. The thicker the material the more it will show up but in light maple plywood it will work out nicely. Optionally you can paint the leaves with a metallic ink pen or add a 4" cork bottom. This will print best if the masking is removed before the engraving, to get the most detail If you fix the material so it cannot be moved and cut out the outline (with the engraving on ignore) the masking can be removed and the disc replaced, the cut can be set to ignore and engraved set to SD.
4.0 x 4.0 x 0.12 in
4"x4" Cork base
Metallic paint pens
