Birthday Candles Greeting Card
Made by Glowforge
Celebrate any occasion with this simple, laser cut greeting card. Cut the two inserts in contrasting colors to create a card with impact! No glue is required to assemble this card which makes creating and gifting it quick and easy.
This laser cutting design uses a card stock and the settings for paper, 80lb cardstock can be found in the Glowforge interface.
0.02 x 4.25 x 5.5 in
- RTRay T.Verified ReviewerI recommend this productRated 4 out of 5 stars2 years agoBirthday Card
I made this card for my Dad's 90th birthday and it turned out great! Hint: Print the card out exactly as downloaded. If you change the size of the card, the corresponding panel will not line up.
Was this helpful? - NNancyVerified ReviewerI recommend this productRated 5 out of 5 stars2 years agoNice layered card
Lasered relatively quick. I used a slightly heavier stock for the outside layer so I increased power just a bit. Turned out great! Thank you for the design.
