Chunky Sunflower with Leaves and Wheat Shelf Sitter Fall Décor (Set of 3)
Our chunky Shelf Sitters are an easy way to decorate for the Fall Season! This set includes 3 laser cut shelf sitters that range from the largest around 7x8 and the smallest around 5x7. Each stands on its own and are 4 layers thick. This simple design is easy for all ages. The project can be sized to be made larger or smaller.
Make sure to check out our other Easely Created Designs here.
60 min
1 x 7 x 8 in
- TBTodd B.Verified ReviewerI do not recommend this productRated 2 out of 5 stars1 year agoUnstable
The designs is not stable. It’s too thin to stand on its own. Needs a stabilizing piece on back.
Was this helpful? - MMMelissa M.Verified ReviewerI recommend this productRated 5 out of 5 stars1 year agoGreat file!
Great file!
Was this helpful? - DDotmaeVerified ReviewerI recommend this productRated 5 out of 5 stars1 year agoTheses are adorable sunflowers
I used walnut and birch plywood which i oiled after printing. I got clipart of a wheat shaft and outlined it so it would have the points on the top. They were a bit wobbly so a added a thin strip of wood behind the sunflower which helped stabilize it a bit.
