Compact Dice Tower - Thicker Material
Made by RetroRob
$14.99
$14.99
A compact version of our Deluxe Dice Tower! This attractive and functional dice tower can be used with any standard-sized dice to enhance your gaming get-togethers! It also collapses down into the base for easy storage. It is designed to fit together with pressure-fit connections and works well with most any material you can cut on your Glowforge! Even holds your dice when it is folded up.
4.25 x 2.4 x 4.25 in
Note: Not Compatible with Light Plywood or Medium Plywood
