Customizable Sliding Door Sign
Made by Crafting with Brenna
Customize this sliding sign for whatever you need! Perfect for marking when a job is done or to signal when a meeting is in progress in your office. Add whatever words you need to make it perfect for you! The back layer is at the top and has a scored box on it. That is where you'll add your options that you want. The next layer is a frame piece with a slider added. The top layer is a frame that you can add some writing around if you'd like. Be careful with the glue! If glue sticks to the slider in the middle, it won't work.
6 min
0.45 x 6.15 x 1.75 in
