Deluxe Puzzle Maze
Made by RetroRob
Can you move the ball from Start to Finish? Have hours of fun and show off what your Glowforge laser cutter can do with this clever puzzle maze. The maze is fully enclosed with a clear acrylic top to keep the stainless steel ball inside! Prints in a jiffy and is easy and fun to assemble.
This is the suggested steel ball to use: 1.5 mm Steel Ball
0.5 x 3.25 x 3.25 in
Rubber Mallet
- LLefTeaLifeI recommend this productRated 5 out of 5 stars2 years agoGreat first project
This was such a fun project, so easy (once I found the right size ball bearing the smallest one at 1/16, at my local hardware store).
I then did a dark walnut stain around the outside frame, and a warm stain on top of the maze, and left the bottom of the maze light basswood.
Was this helpful? - NNancyVerified ReviewerI recommend this productRated 5 out of 5 stars2 years agoMaze
Great game. Use a tiny bead
Was this helpful? - JTJohn T.Verified ReviewerI recommend this productRated 5 out of 5 stars2 years agoPuzzle maze
Need to add what size ball to use. I found that a 1.5 mm works.
Was this helpful? - VvicTORIaVerified ReviewerRated 3 out of 5 stars2 years agoThe ball kept getting stuck
I loved the design! Anything snap together that doesn’t require glue is just so cool! But as I played I realized one section of puzzle wall that was a little loose and when the whole thing snapped together the wall had move a hair. This blocked the ball from getting to where it needed to go. I had to take the whole thing apart glue the loose piece down where it needed to be and then put it all back together. It was a pain.
Was this helpful? - JHjoyce h.Verified ReviewerI recommend this productRated 4 out of 5 stars3 years agocute maze!
I have mixed feelings! It is super cute and I can see possibilities. But it is so small, the bead is so small, the print is so small. To make it larger would mess with kerf and no time for that! A little tweaking and it would be great!
