Easy Silicon Caulk Guides
Made by deirdrebeth
Silicon caulk guides allow you to get that perfect flat angle, rather than the dished one that your finger will leave. The silicon caulk will wipe easily off the acrylic when you're done, and if it dries, you can still roll it off! These guides will work whether your walls are square or not (and they're never square!), and the handy hole allows you to run a connector through them so they're always together when you next go looking for them. The numbers are in mm, and allow you to grab the same one each time if you're doing multiple projects over an extended period.
Ball Chain
Ball Chain
0.13 x 2.5 x 2.5 in
Ball Chain
