Engraving Material Support Set (Painters' Pyramids)
Made by Dennis Ward
Every Glowforge user should have a set of these laser cut material supports printed and ready to go. They make it easy to raise materials too thick for use with the crumb tray but too thin to engrave as-is. Why print three of each size instead of four? Three-point supports are inherently stable, while four points can easily introduce a wobble. If you prefer more support, why not print extras? These supports are perfect for using up PG scraps. Pro Tip: The No Math Focus Ruler available in the Catalog makes determining the optimal material height quick and easy.
1.5 x 1.5 x 1.5 in
- TTLDovesVerified ReviewerI recommend this productRated 5 out of 5 stars3 years agoPrinted great!
Printed great!!!
