Famous Fiery Flaming Phoenix Flippable Earrings
Made by Robert Danforth
What better to have risen out of the fire of your 'Forge than a fair pair of fiery Phoenixes! A fine web of filaments or a delicate engraving on both sides. First tightly secure the material before cutting Then, with the engrave set to ignore, cut, and remove masking. Then set cut to ignore, engrave to SD, and run engrave. Then carefully remove and replace upside down in the opposite hole, and rerun the file without making any adjustments. If the material and design image have not moved, it will be engraved in the same place.
0.12 x 1.5 x 1.75 in
