1 of 11
Glowforge Aura
Unlock a new dimension to your creativity with Glowforge Aura™ Craft Laser™. Its powerful laser precisely cuts, engraves, and scores hundreds of materials so you can bring your ideas to life in minutes.
4.5
Rated 4.5 out of 5 stars
83 Reviews
Buy the Glowforge Aura
  • Glowforge Aura, ready out of the box
  • 12 Month Worry-Free Warranty
Regular price $999
Regular price $1,199 Sale price $999
Limited time: Get a FREE replacement cartridge ($129 value) with purchase!
Add Filter Cartridge to cart to apply.
Flexible payment options available:
Ships to US customers only
Compatible with your Mac, PC, tablet or phone
Import designs in your favorite formats
Infinite prints with Aura Passthrough
Preview Mode sees before you print
Autofocus and 3D Engraving
Safe for creating at home
Works with 100s of materials
Unleash Your Creativity
Product Details
Glowforge Exterior Dimensions
Glowforge Aura
Dimensions
Glowforge Aura exterior: 22″ x 20.5″ x 5″ (556mm x 521mm x 127mm)
Air Filter Exterior Dimensions
Material dimensions Work Area
Max materials depth: up to 1⁄4” thick
Max material size: 12” x 12” inches
Cutting area approx: 144 in sq.
Glowforge Aura can cut materials up to 1/4" thick, and engrave materials up to 3/4" thick with the cutting tray removed.
Material Capability
Can safely print on any laser-compatible material, including the examples below. Glowforge recommends using Aura-compatible Proofgrade® materials for smart settings and perfect results. Proofgrade materials are specially sourced and lab-tested for creating prints safely at home.
Note: Most Proofgrade materials work beautifully with your Glowforge Aura, but we recommend against using Draftboard™, medium plywood, and clear, white, and blue acrylic. All other acrylic colors, and both Light and Thick plywoods, will work wonderfully. Learn more about laser-compatible materials here and see our collection of Aura-compatible Proofgrade materials here.
CAUTION: Laser cutting vinyl will immediately destroy your laser. As an alternative, try our Eco Iron-On material.
Engrave and Cut:
Wood image
Wood
Acrylic image
Acrylic
Leather image
Leather
Veneer image
Veneer
Paper image
Paper
Cardboard image
Cardboard
Delrin image
Delrin
Mylar image
Mylar
Rubber image
Rubber
Cork image
Cork
Sandpaper image
Sandpaper
Food image
Food
...and hundreds more!
Engrave only
Stone image
Stone
Slate image
Slate
Titanium image
Titanium
Aluminum image
Aluminum
Marble image
Marble
Ceramic tile image
Ceramic tile
Corian image
Corian
Software
Easy-to-use, web-based software will have you printing in minutes
Glowforge App works with Mac, PC, Chromebook, tablet, and phone
Compatible with JPEG, PNG, SVG, PDF, and other popular file formats
Aura Vision™ live camera preview lets you visualize your designs on your materials
Automatically scan and print drawings and print without design software
Choose from a catalog of premium, customizable, ready-to-print designs
One Button Print
When used with Proofgrade materials, automatically determines settings for perfect cutting and engraving
Cameras
Wide Angle Camera — Mounted on the lid, provides a view of the entire printable area
Lighting
High-efficiency internal LED lighting gives your work broad illumination for a wide angle view and precise precisioning
Laser System
The Glowforge Aura Craft Laser is certified as a Class 1 laser product containing an embedded Class 4 laser
Mechanicals
Case — High modulus injection molded plastic
Linear System — Glass filled injection molded linear rails and steel slides with belt driven carrier
Motion — Hybrid stepper X and Y axis
Cooling/Air Assist — Custom laser head fan for combined cooling and air assist
Recommended Operating Temperature: 60F-75F (16C-24C)
Requirements
Wi-Fi required (2.4 GHz b/g/n and WPA2, WPA, or open)
Ventilation with either the Glowforge Personal Filter, or an open-able window within 8 feet
110/220 VAC, 50 or 60 HZ outlet
Glowforge Aura has 84W peak power consumption
Miscellaneous
Precision power settings allow enough control to draw lines on copy paper
3D engrave settings carve detailed surfaces
Glowforge Aura Upgrades
Glowforge Aura Passthrough slot allows the use of material that’s up to 3/8″ (9.5mm) high, up to 12” (30.48cm) long, and as wide as desired
Safety
Certified to UL standards
Safety sensors alert in case of bumps or unplanned movement
Safety sensors warn in case of overtemperature conditions
Safety sensors notify when fan performance changes
The Glowforge Aura is certified as a Class 1 laser product containing an embedded Class 4 laser and comes with all necessary safety training materials
Certified to EN/I EC 62368-1:2014 EN/I EC 60825-1:2015 CAN/CSA C22.2 No. 62368-1-14:2014 UL 62368-1:2014 by TUV Rheinland
Safety
Warranty
12 Month Comprehensive Warranty
Full warranty info at glowforge.com/warranty
Bring your ideas to life, like magic!
Speak to an expert
Give one of our Glowforge experts a call or instantly chat online.
Glowforge Craft Laser™ Filter
Regular price $399.00
Regular price Sale price $399.00
Lasers like your Glowforge Aura require ventilation. With the Glowforge Craft Laser Filter, you can put your Glowforge Aura anywhere! It sits on the ground near your Glowforge Aura and cleans the air, allowing you to operate it anywhere in your home.
Why you will love Aura
Laser power & precision
Precisely cut, engrave, and score with a beam of light.
Preview Mode
Preview, perfect and visualize your prints before you print.
Simple & intuitive
Easy-to-use tools & step-by-step tutorials make creating a breeze.
Endless possibilities
Create millions of projects from hundreds of materials.
What Our Customers Are Saying
4.5
Based on 83 reviews
Slide 1 selected
83 reviews
  • M
    Mitchell
    1 year ago
    Straightforward and Foolproof
    I've mostly been using it on paper for stencils so far. It's nice and easy to pop in .SVG files, you can rescale, rotate, reposition. Decent size relative to the cutting area, and you can open the sides to slide through longer material. It comes in a nice box that I'm holding onto for whenever I move. Pretty minimal plastic packaging. I got the filter, it turns off and on by itself. With paper there's a little bit of a burnt wood smell that dissipates quickly. I've got some 1/8" basswood I'm going to try out next. Overall really solid if you're looking for a plug-n-play laser.
  • FA
    Fabiana A.
    1 year ago
    I LOVE my Aura!
    I love love loveeee my Aura. I had a Cricut before it and all I can say is what an upgrade! First of all, setting it up was super smooth. The box comes with a QR code that guides you step by step on how to get it up and running and it was super user friendly. Now, the laser itself is gorgeous. It has such an aesthetic design that I do not mind having it on my desk (plus the size is perfect). It is also really easy to move around in case you didn’t have a designated place for it. The laser comes with a hose and power outlet and it is basically ready to use. I was a little intimidated by the learning curve but honestly it is super intuitive and if I you use their Proofgrade materials it makes it even easier. I think this is the perfect laser for any crafter, and I totally recommend!
  • TI
    Tiffany I.
    1 year ago
    Great purchase!
    This is a great tool. I have been having so much fun engraving whatever I can get my hands on.
  • AC
    Ashley C.
    1 year ago
    Crafting elevated!
    Full disclosure: I was a beta tester, so I’ve been able to use this machine before others. There’s some really important information that’s missing from the listing, so read carefully and make sure you’re buying the right product for what you need.
    First - don’t be mistaken, this isn’t the laser that made Glowforge famous. Aura is less powerful, cheaper, smaller, lighter, and a lot more orange but the Aura has completely transformed my crafting! Setting up the Glowforge Aura was an absolute breeze (you just need wifi). The step-by-step instructions were incredibly easy to follow. Within minutes, I had it up and running. There’s just one button. When it lights up, you push it.
    One of the most important features: It’s safe. Glowforge is the only laser I know that has a 3rd party testing certificate. With a 6 month old baby, this was extremely important to me.
    One of the standout features of the Glowforge Aura is the Glowforge Proofgrade materials. These materials are specifically designed to work seamlessly with the laser cutter, ensuring consistent and high-quality results. The variety of materials available is impressive, from wood and acrylic to leather. I tried to save a bit of money and use other materials and although they work great, it takes so much more time and effort. I ended up buying the Proofgrade materials and now I won’t go back! They are so much easier and high quality.
    The Glowforge Aura can cut through a wide range of materials with precision. Whether…
  • NK
    Neysa K.
    1 year ago
    Works great out of box for this experienced laser user!
    I bought this product a couple of months ago and wanted to put it through it's paces before writing a review. I have several years experience with laser cutters/engravers, and was upgrading from an older machine to something a bit newer/quicker, and perhaps a little more user friendly.
    I was immediately impressed by how well this laser worked right out of the box. Had everything set up and printed my first test project within a half hour. It's pretty slick, I think for a first-time laser purchase this thing is pretty much ideal. There are plenty of pre-made projects you can hop into straight away, and even more if you purchase the membership or are in the trial period. The membership wasn't for me in the long run, but it was great way to start off, and for people who don't want to get into the weeds with creating designs and cuts in other pieces of software and importing them into the Glowforge interface, I think it would be well worth the money. Like many users I tend to use GIMP & Inkscape to create my projects, but pretty much any graphics program such as photoshop should work, so long as you can export image files and SVG graphics. So don't let the membership aspect sway you away from this laser; if you feel like you have to pay a monthly fee to use it, you absolutely do not.
    I read some reviews talking about the speed of this laser, with some people expressing disappointment with it's speed. That all depends on your perspective. It's important to note that this is a…
Frequently Asked Questions
What materials can I use with my Glowforge Aura?
Glowforge Aura fits material up to 12 in x 12 in (30.4 cm x 30.4 cm) and works with thicker materials than craft cutters — you can cut materials up to ¼ in (0.635 cm) thick and engrave objects up to ¾ in high. It cuts and engraves laser-compatible materials including wood, acrylic, leather, veneer, paper, & cardboard, and also engraves on denim, mylar, rubber, cork, sandpaper, food, stone, slate, titanium, aluminum, marble, ceramic tile, and hundreds more!
Glowforge Aura uses a blue, 6-watt, solid-state laser, so it is not compatible with glass, clear acrylic, white acrylic, blue acrylic, vinyl, or Draftboard®️ materials.
What is the thickest material that Glowforge Aura can cut?
What is the difference between Glowforge Pro, Plus, and Aura?
All Glowforge printers are quick to set up and easy to use. You can choose to work with hundreds of materials to make the kinds of amazing things that you see on our Community Forum or Instagram. All our printers come with everything you need to get started making magical things at the touch of a button.
If you want to make projects at home like paper greeting cards, personalized signs, or acrylic accessories, then Glowforge Aura is perfect for you. If you’re looking for even more speed, power, or the ability to create products for a business, then check out our Performance Series.
Do I need additional software to print with a Glowforge?
No! Every Glowforge laser works with our web-based App, Glowforge Print. You can use your Mac, PC, tablet, or smartphone to access the Glowforge App. To create a print, design a project completely from scratch right in the App — choose from millions of fonts, graphics, pattern tools, stamp-templates, & more! You can also choose thousands of ready-to-print designs from the Glowforge Catalog, and customize them to make your perfect project!
If you prefer, use your favorite software (like Adobe Illustrator, Inkscape, CorelDraw, Adobe Photoshop, GIMP, Autodesk 360, Sketchup, and more) to create a project in your favorite file formats like JPG, PNG, SVG, or PDF, then easily drag-and-drop it right into the Glowforge App.
How much space will Glowforge Aura take up in my home?
The Glowforge Aura is 22 in (W) x 20-½ in (D) x 5 in (H) — or about the size of a large printer.
How easy is it to get started?
It takes less than 30 minutes to get your printer out of the box, set it up, and finish your first print.
How precise is the Glowforge laser?
Glowforge uses a beam of light the width of a human hair to cut and engrave with incredible accuracy to one-thousandth of an inch. It can engrave images in stunning high-resolution comparable to what you see on your phone or computer screen now. Learn more here!
What kind of warranty is provided on your products?
Glowforge offers a manufacturer's twelve-month worry-free warranty on your Glowforge purchase, with full warranty info available at glowforge.com/warranty. Glowforge has partnered with Mulberry to provide you with the option to extend your product protection. Your Mulberry protection will extend your manufacturer warranty and also add additional protection for accidental damage (see Mulberry terms and conditions for specific coverage details). As you are shopping, we’ll let you know exactly what is covered for the products you’re interested in. Learn more at https://shop.glowforge.com/pages/extended-warranty.
