1 of 11
Glowforge Pro - Certified Rebuilt
The Glowforge Pro - Certified Rebuilt Laser Engraver can help you create high-quality custom gifts and decor by engraving on wood, acrylic, glass, leather and more.
Regular price $2,999.00
Regular price Sale price $2,999.00
  • Glowforge Pro - Certified Rebuilt, ready out of the box
  • $150 worth of FREE Proofgrade materials
  • 3 Month Manufacturer's Guarantee
  • Lifetime free access to Glowforge Print software
includes $150 of FREE Proofgrade® Materials
Allows you to operate your Glowforge anywhere in your home, school, or office! Learn more
Flexible payment options available:
10x faster top speed compared to Spark
Giant prints with Pro Passthrough
Our most powerful 45w laser
Print all day with enhanced cooling
Live Camera View
Simple setup in under 30 minutes
Works with hundreds of materials
As of 2025, all Performance Series lasers are proudly designed, made and serviced in the USA!
Product Details
Glowforge Exterior Dimensions
Glowforge Pro
Dimensions
Glowforge exterior (Pro and Plus): 38″ x 20.75″ x 8.25″ (965mm x 527mm x 210mm)
(Pro and Plus)
Performance Laser Filter Exterior Dimensions
Material dimensions Work Area
Cutting area: approx. 11" (279mm) deep and 19.5" (495mm) wide
Maximum material depth: 18" (455mm) for Plus; unlimited for Pro
unlimited for Pro
Maximum material width: 20" (515mm)
Maximum material height: 2" (50mm)
Maximum material height with tray: 0.5" (13mm)
Material Capability
Can safely print on any laser-compatible material, with examples below. Glowforge recommends Proofgrade™ materials for automatic settings and perfect results.
Engrave and Cut:
Wood image
Wood
Acrylic image
Acrylic
Leather image
Leather
Draftboard image
Draftboard
Veneer image
Veneer
Paper image
Paper
Cardboard image
Cardboard
Delrin image
Delrin
Mylar image
Mylar
Rubber image
Rubber
Cork image
Cork
Sandpaper image
Sandpaper
Food image
Food
...and hundreds more!
Engrave only
Glass image
Glass
Stone image
Stone
Slate image
Slate
Titanium image
Titanium
Aluminum image
Aluminum
Marble image
Marble
Ceramic tile image
Ceramic tile
Corian image
Corian
Software
Easy and powerful interface will have you printing in minutes
Web interface works on Mac, PC, Linux, and many mobile devices (internet required)
Compatible with JPG, PNG, SVG, PDF, and other file formats.
Glowforge Premium includes support for DXF files
Drag-and-drop layout with live camera preview to position designs on the material
Automatically scan drawings and print without design software
Catalog of premium, customizable, ready-to-print designs
One Button Print
When used with Proofgrade materials, automatically determines settings for perfect cutting and engraving
Cameras
Wide Angle Camera — Mounted on the lid, provides a view of the entire printable area, accurate within 0.25” (6mm)
Macro Camera — Mounted on the head, provides extreme up-close information for autofocus, accurate within 0.004” (0.1mm)
Lighting
Dual high-efficiency internal LED strips give your work broad illumination for a wide angle view
Headlights under the lid give point illumination for precise precisioning
Laser System
CO2 Laser — Custom CO2 glass laser tube capable of continuous operation at 10,600 nm; rated at 45 watts for Pro and 40 watts for Plus
Fixed Alignment — Factory calibrated optical system does not require any alignment by the user
Sealed Optics — Enclosed optical path with cleanable and replaceable windows protects the laser optics to avoid replacement or realignment
Mechanicals
Case — High modulus injection molded plastic
Linear System — Custom extruded aluminum linear rails with belt driven v-wheel carrier
Motion — Dual hybrid stepper Y axis; single hybrid stepper X axis
Cooling — Closed loop self contained internal cooling.
Air Assist — Internal air assist with no external compressor hookup required
Recommended Operating Temperature: 60F-75F (16C-24C) Plus; 60F-81F (16C-27C) Pro
Requirements
Wi-Fi required (2.4 GHz b/g/n and WPA2, WPA, WEP, or open)
Ventilation with either the Glowforge Performance Laser Filter, or an open-able window within 8 feet
110/220 VAC, 50 or 60 HZ outlet
Glowforge Plus and Pro have 800W peak power consumption
Performance Laser Filter has an additional 350W peak power consumption
Miscellaneous
Precision power settings allow enough control to draw lines on copy paper
3D engrave settings carve detailed surfaces
Positioning precision to 0.001” (0.025mm)
Engraving up to 1355 DPI
Glowforge Pro Upgrades
Pro Passthrough slot allows the use of material that’s up to 1/4″ (6.3mm) high, up to 20” (50.8cm) wide, and as long as desired
Upgraded solid state thermoelectric cooling
Safety
Certified to UL standards
Safety sensors alert in case of bumps or unplanned movement
Safety sensors warn in case of overtemperature conditions
Safety sensors notify when fan performance changes
The Glowforge Plus is a Class 1 laser device with no special training required
The Glowforge Pro is a Class 4 laser device and comes with all necessary safety training materials
Certified to UL/ANSI/IEC 60950-1-07 and CAN/CSA-C22.2 NO. 60950-1-07 (R16) by TUV Rheinland
Safety
Warranty
12 Month Comprehensive Warranty
Full warranty info at glowforge.com/warranty
Bring your ideas to life, like magic!
Speak to an expert
Give one of our Glowforge experts a call or instantly chat online.
Contact Us
Regular price $1,295.00
Regular price Sale price $1,295.00
Our Performance Laser Filter upgrade lets you put your Glowforge anywhere.
Lasers like your Glowforge require ventilation. All Glowforge printers come with a 4” (10 cm) diameter hose which allows you to use your Glowforge near a window. It sits on the ground near your Glowforge printer and cleans the air, allowing you to operate it anywhere in your home, school, or office!
Make just about anything
Key Benefits
Precisely cut, engrave, and score hundreds of materials up to ½” thick with a professional-grade laser.
Engrave photographs, patterns, or text in vivid detail onto materials like wood, acrylic, stone, leather, and more.
Create infinitely long projects using the Passthrough slot with continuous auto-tracking.
See exactly what you’re printing with live camera preview and precise autofocus.
Frequently Asked Questions
Which Glowforge is right for me?
Great question! Every Glowforge laser is easy to set up and comes with everything you need to get started creating with hundreds of materials on Day 1. There are 2 series of Glowforge lasers:
  • Our Performance Series is for people who want our fastest, most powerful lasers whether it's for a powering business, starting a side hustle, or teaching in the classroom. It includes Glowforge Pro HD (our fastest laser ever!), Glowforge Pro, Glowforge Plus HD, and Glowforge Plus lasers.
  • Our Craft Series is for  crafters and other creative enthusiasts looking to level-up their making with compact, easy-to-use lasers. It includes Glowforge Aura and Glowforge Spark Craft Lasers.
Whichever Glowforge laser you choose, it’ll be easy, fast, and fun to get started: within thirty minutes of receiving your Glowforge, you can be holding your first finished print! Here are some more details to help you make the right choice for you!
How is Glowforge different from a 3D printer?
Glowforge uses subtractive manufacturing while traditional 3D printers use additive manufacturing. A 3D printer builds up material, like plastic filament, layer by layer. With Glowforge, you’ll put a piece of material like leather, wood, or acrylic in the machine and it carves out your product using laser light. The technical name for the category of tools that includes Glowforge is a CNC laser cutter engraver, but that's a mouthful, so we call it a 3D laser printer.
What can I make with Glowforge?
You can make an endless variety of useful, beautiful, and practical things from a bunch of different materials like wood, leather, felt, fabric, acrylic, paper, and more. See what amazing things other Glowforge owners are making over on Instagram, #glowforge.
What kind of software and hardware do I need to use Glowforge?
Great news! You can use your Glowforge from a Mac, PC, tablet, and smartphone, using our simple, powerful, and free web interface.
Will Glowforge be difficult to set up or learn how to use?
Glowforge is incredibly easy to use. Most of our customers tell us it takes them less than 30 minutes to get their printer out of the box, plug it in, set it up, AND finish their first print!
The web interface, point-and-click software, and simple hardware (just one button!) combine to make it both simple and easy to use.
Your Glowforge comes with a detailed manual to help you learn to use it easily and quickly. We also have many resources to help: our community forum answers most questions within hours, our detailed learning information at glowforge.com/support answers the most frequently asked questions, and we’re always here to help if you have a question.
We’ve seen incredible creativity from people ranging from preschool students to great-grandparents. We have no doubt you’ll be able to create amazing things!
What kind of warranty is provided on your products?
Glowforge offers a manufacturer's twelve-month worry-free warranty on your Glowforge purchase, with full warranty info available at glowforge.com/warranty. Glowforge has partnered with Mulberry to provide you with the option to extend your product protection. Your Mulberry protection will extend your manufacturer warranty and also add additional protection for accidental damage (see Mulberry terms and conditions for specific coverage details). As you are shopping, we’ll let you know exactly what is covered for the products you’re interested in. Learn more at https://shop.glowforge.com/pages/extended-warranty.
