Heirloom Dry Fly Box
Made by Dennis Ward
3.0
Rated 3.0 out of 5 stars
$14.99
$14.99
Create a one-of-a-kind heirloom fly box - a perfect gift for the fly fisher in your life (or even you!). This box is designed for laser cutting and is meant to utilize common 6-inch foam inserts. The design includes a woodcut from 1818, but feel free to customize it any way you desire. There’s plenty of space on the back to engrave an inscription and your maker’s mark. Don’t care for the inserts? No problem – cut some EVA or other laser-safe foam and make your own. Not into fishing? Cut some laser-safe felt to line the bottom and use it as a jewelry or curio box.
To complete this laser cut design, the following items are required:
- Foam Inserts (2 pcs., choose your preferred style)
- Magnets (⅛” or 3mm, 4 pcs.) Check sizes as links can change in Amazon
- Hinges (8mm, 2 pcs.)
30 min
0.75 x 5.5 x 4.25 in
Magnets (3mm)
Hinges
Elastic Bands
Assembly
Rated out of 5 stars
0
Total 5 star reviews: 0 4
0
Total 4 star reviews: 0 3
Total 3 star reviews: 1 2
0
Total 2 star reviews: 0 1
0
- JJanetVerified ReviewerRated 3 out of 5 stars2 years agoFly B0x
It's a beautiful box.
I had a few problems though.
First of all the links were inaccurate, The magnet link and the foam inserts were too large. I found the correct magnet size and just cut the foam to fit.
Also, the magnets don't match up when you close the box. Everything is even and matches perfectly, but the magnets don't match, so it doesn't close tight.
Loading...
Loading...
