Howling Wolf Earring and Pendant Necklace Set
Made by Raeleen
An Abstract Mountain Owl with a nod to the Northwest Style which contains the mountains forests, and broad rivers that are key aspects of the nature of the area. These earrings are designed to be engraved on both sides. By tightly securing the material before cutting with the engrave on ignore. Carefully lift the pieces out, remove the masking, and run the engrave only, Then remove and replace upside down in the opposite hole and, run the engrave again without making any adjustments. As long as the material has not moved it will engrave in the same place.
0.14 x 2.15 x 2.26 in
Earwires
Necklace Chain
