Knitting Crochet Tags (Set of 7)
These custom tags are perfect to add to your knitting or crochet projects. You can sew them on any of your woolen fabrics, such as hats, sweater coats, stuffed toys, etc. The tags are 0.80 inches and are not only small and cute but also very durable. Few options are provided or you can customize to your need to make clothes or hats more distinctive and meaningful. These tags are designed for laser cutting. Walnut is used on the image, however, you can use other medium proofgrade material for a different look.
0 min
0.125 x 0.8 x 0.5 in
- JJennieVerified ReviewerI recommend this productRated 5 out of 5 stars2 years agoFantastic!
Perfect size as is, and cuts perfectly
Was this helpful? - EEagelstonmaVerified ReviewerI recommend this productRated 5 out of 5 stars2 years agoAnd a blank tag to personalize
These cute tags cut wonderfully. I shrunk some a bit to match the size of the item proportions.
Was this helpful? - EEagelstonmaVerified ReviewerI recommend this productRated 5 out of 5 stars2 years agoSuch a novel idea for tags
I used the blank and put my logo on it then sewed them onto crochet Starwars characters. I left half of them natural and colored the other with bell marker.
