Knotwork Elder Futhark Viking Rune (Set of 24 With Blank)
Made by Olofsfjall Arts
A historically accurate (correct ingwaz) Elder Futhark rune set, designed for laser cutting, featuring a scored knotwork pattern and engraved rune. A blank is included for those that wish to use this newer incorporation.
0.125 x 1 x 1 in
- BCBrenee C.Verified ReviewerI recommend this productRated 4 out of 5 stars2 years agoGreat with a bit of tweaking!
I printed these on poplar wood and as you can see in the pic, the rune marks are very nice & clear. But the cool knotwork ring is very faint, especially if it had to print over the QR label, and some are off-center to the cut out circle itself. None of the knot work fell outside the cut line so that's good. My biggest fix would be the clarity of the knot work. I tried to go back and make sure it used the QR code "poplar setting" just to check if it was that, but when I pulled it up again it did not say. I usually check that it's reading the code correctly, so I assume it read the label- that's not been an issue. (There are 2 pics of the same thing. It's only showing me an ? in the pic box, so I hope you're able to see it)
