No Math Focus Ruler
Made by Dennis Ward
The easiest way to make sure items are within the allowable focus range when the crumb tray is removed. No math, measurements, or calipers required!
As a reminder, do not put anything in your Glowforge printer that is not laser-compatible, even if you do not intend to cut or engrave it. This design is not meant to be printed on non Proofgrade material. If you are not using Proofgrade materials, please check with the material manufacturer to ensure the product can safely be used in your Glowforge. Use of controls, adjustments, or performance of procedures other than those included in the Glowforge manual(s) or with this design may result in harm to you or your machine. Printing on potentially non-laser compatible material or with the wrong settings can result in damage to your Glowforge. Additionally, any damage resulting from problems using potentially non-laser compatible material or manual settings is not covered by your warranty. This design is not meant to be used outside of the prescribed settings, description/uses of the design, and design instructions, and Glowforge is not responsible for any such deviation.
Print time
4 min
0.125 x 1.5 x 3 in
CommercialProduct Highlights
- LKLena K.I recommend this productRated 5 out of 5 stars5 days agoNo math ruler
Fun and useful
Was this helpful? - BABirgit A.Verified ReviewerI recommend this productRated 5 out of 5 stars3 weeks agoFocus Ruler
It’s genius. Works great.
Was this helpful? - SFSharon F.I recommend this productRated 5 out of 5 stars3 weeks agoOwner
Big Help
Was this helpful? - KPKaren P.Verified BuyerI recommend this productRated 5 out of 5 stars2 months agoVERY HELPFUL
I had this but could not find the file. I love it and use it allot.
thank you.
Was this helpful? - AHAmanda H.Verified ReviewerI recommend this productRated 5 out of 5 stars2 months agoVery Helpful Tool
This is a very helpful tool when you have to remove the crumb tray for a thicker material.
