No Measure Engraving Zone Tool
Made by Analytical Mommy
$1.49
$1.49
This tiny but powerful tool helps you visualize whether a material is thin enough to use with the crumb tray in place, if you need to remove the crumb tray, if you need to raise your material up after removing the crumb tray, and if it’s too thick even without the crumb tray! All in such a small piece of wood you can make with your scraps! Just cut the outside and score the inside parts and you’re good to go! When you’re ready to use it, hold the tool by the loop at the top, and stand it up next to your material to see where the top of the material reaches on the tool. Can be made out of just about any material but i’ve made mine out of Light Maple Plywood. Designed exclusively for the Glowforge Aura.
0.12 x 1.64 x 3.434 in
