Ornament Display Stands (Set of 2)
Made by Jon Canfield Creations
4.0
Rated 4.0 out of 5 stars
5 Reviews
Here's a quick and easy laser cut print, perfect for displaying your ornaments or for photographing them. Made with Medium Clear Acrylic, the entire laser cutting project is only about 2 minutes start to finish. The design includes two different options for the stand - a straight or a curved. The base has a slot for the tab to snap into. It's a snap fit with no glueing needed.
3.0 x 3.0 x 8.0 in
Based on 5 reviews
Total 5 star reviews: 2 Total 4 star reviews: 1 Total 3 star reviews: 2 Total 2 star reviews: 0 Total 1 star reviews: 0
5 reviews
  • NC
    Nora C.
    1 year ago
    Perfect for keychain photos!
    It's perfect for taking photos! I use them specifically for keychain photos!
  • TS
    Theresa S.
    3 years ago
    Ornament stand
    It came out great
  • P
    Patrice
    Rated 4 out of 5 stars
    3 years ago
    Great ornament stand
    I made the curved stand...The bottom portion of the long curved arm is a separate piece. When I moved it, it separated. It was a good thing that I noticed it before I printed it...I think part of the issue is when it uploads, the 2 square pieces are grouped with the curved arm and you have to ungroup it . When you do this it ungroup everything....maybe the arm should be one piece and not 2.....didn't use the straight arm...
  • BD
    B. Dione B.
    Rated 3 out of 5 stars
    3 years ago
    Ornament stands
    The slots on the bases are cut the same size and the arched ornament holder does not fit either one. The slot needs to be adjusted for that one. Was looking forward to using them at my pop up event.
    Glowforge Shop
    3 years ago
    Thank you for your review of this design, your feedback is very much appreciated. We have updated the SVG and the file should work correctly now.
  • J
    Josh
    3 years ago
    Some modifying needed
    The straight stand fit perfect but the the curved stand slot was to small had to sand the notch to make fit
