Painter's Pyramids
Made by VARO Industries
Painter's pyramids are used to elevate your work piece off of a surface to ensure that paint, varnish, or other material you are applying to your work does not stick to the surface it is sitting on, and allows you to better control drips or spills. These are simple, quick laser cut prints you can make to easily make these handy tools as you need them, and it does not require a lot of material. The corners are slightly rounded, so you also do not mar your work.
1.7 x 1.7 x 1.3 in
CA (Cyanoacrylate) glue
- BBesh76Verified ReviewerI recommend this productRated 5 out of 5 stars2 years agoEasy convenient little tools
I was happy to find this little design to use as risers in my glowforge. Came in handy in a pinch. Also love that I could adjust them to the size I needed.
Was this helpful? - DGDebbie G.Verified ReviewerI recommend this productRated 5 out of 5 stars2 years agoExcellent File
This file was a life saver in projects.
