Personalizable Easter Basket Tags - Diagonal Plaid Eggs (Set of 2)
Elevate your Easter gifting with our personalizable egg-shaped tags. This 2-layer design features a diagonal plaid-inspired top, and solid backer. Choose between 2 top layer options: the solid center for engraving, or the open center to add your own cutout name. Examples shown are made from light cherry plywood, but you can mix and match plywood and acrylics, or use the engravable top layer by itself, making this a 3-in-1 design. Customize with names or messages for a unique and thoughtful touch.
*Print time listed is the approximate time for both designs and will vary based on the names used.
0.24 x 3.0 x 4.42 in
3M Double-sided Adhesive
1 review
  • H
    Harry
    10 months ago
    Liked the design eas going to make one for all the grandkids
    But I wasted 4 sheets trying to cut these some would come out not matched others would cut the second cut off the position of the first cut. I contacted Glowforge and the responded well . Trying their suggestions now. I will have to wait for next Easter to give them out since I’m out of wood.
