Personalizable Easter Basket Tags - Plaid Eggs (Set of 2)
Elevate your Easter gifting with our personalizable egg-shaped tags. These 2-layer designs feature a plaid-inspired top and solid backer. Choose between 2 top layer options: the solid center for engraving, or the open center to add your own cutout name. Examples shown are made from light cherry plywood, but you can mix and match plywood and acrylics, or use the engravable top layer by itself, making this a 3-in-1 design. Customize with names or messages for a unique and thoughtful touch.
*Print time listed is the approximate time for both designs. Actual time will vary based on the names used.
0.24 x 3.0 x 4.42 in
3M Double-sided Adhesive
