Ring Templates Various Sizes
$2.49
$2.49
This design contains ring templates sizes from 4 to 13.5, including half sizes. The rings can be laser cut from any thickness material. The thicker your material, the wider your rings will be.
Laser cut and leave as is after printing, or sand the material to round the edges and make smooth. Layer materials, add shapes, engrave designs or text...the possibilities are endless!
Depending on usage, keep in mind the thinner the material the more susceptible it becomes to breakage. Although it is not the only method, to reinforce material such as wood, we do recommend a common method of applying a finish of CA glue.
0 min
0.25 x 1 x 1 in
