Santa Meter Ornament - Ornament With Mechanical Arrow And Rail
Made by Ivan Bilous
The description is perfect as it is. It mentions "Laser Cut" and does not mention vinyl. No changes are needed.
0.71 x 2.67 x 2.71 in
- RRandyVerified ReviewerI recommend this productRated 4 out of 5 stars2 years agoLooks amazing works ok
I think the ease of creating it was awesome but the actual workings of it are not as good. Trying to slide the arm from side to side causes it to slip out of the groove its in. Maybe if there was something to help hold it in line it would work better. Other than that it looks amazing and the kids love it.
Was this helpful? - RRonVerified ReviewerI do not recommend this productRated 1 out of 5 stars2 years agoSorry
The design is nice except for the lever used to move the needle. The fit is so tight if you force it-you will probably break it.
Was this helpful? - APAnthony P.Verified ReviewerI do not recommend this productRated 1 out of 5 stars2 years agoWrong dimensions
I have to rework much of the design because the hole sizes are wrong
