Single Ear Wire Jig (Loop Fits ⅛” Material)
$2.49
$2.49
This laser cut ear wire jig will produce earring hooks with a loop that fits 1/8" material. If you cut a lot of earrings with your Glowforge, this little jig will eliminate your need for jump rings! That's right, NO MORE JUMP RINGS!! This single earring jig is made to be used with 2" ball pins, and it's laser cut out of 1/4" acrylic.
Recommended Supplies From Designer: 50mm Ball Head Pins (Wire 0.8mm/ 0.031 inch/20 Gauge)
0.8 x 0.87 x 0.25 in
Jewelry Accessories
