1 of 7
Small Decorative Faceted Tabletop Lantern
Made by Mike Mikkelson
3.8
Rated 3.8 out of 5 stars
5 Reviews
Regular price $9.99
Decorative tabletop lanterns in 3 sizes are a perfect addition to any décor. Add a battery powered candle or fairy lights to showcase the elaborate floral engraving. These lanterns are designed for laser cutting. Print the lantern with or without the engraving on the acrylic faces.
12 min
6.6 x 7.6 x 12.4 in
    1x Walnut Plywood
    1x Clear Acrylic
Based on 5 reviews
Total 5 star reviews: 2 Total 4 star reviews: 1 Total 3 star reviews: 1 Total 2 star reviews: 1 Total 1 star reviews: 0
Slide 1 selected
5 reviews
  • GS
    George S.
    Verified Buyer
    Rated 3 out of 5 stars
    2 years ago
    tabletop lantern
    Frankly I am disappointed. The wood pieces fit a little too loose. I would have liked a design on the acrylic that was not so busy. 3 1/2 hours of engraving is to time consuming on such a small project.
  • KC
    Kate C.
    2 years ago
    This is a beautiful lantern when completed. Instructions were a little bit confusing. I assembled the frame completely as shown and then was concerned about how to get the acrylic pieces into place. I began with the bottom pieces and used a bone folder to "pry the middle wood section up slightly so that the tabs would pop into place. This worked well. For the top section of acrylic if the top tab is inserted first the bottom pops into place easily. The design does not have a place to insert the candle unless you plan to remove one of the top acrylic sections so I added a cut out in the bottom so that it would sit down over a flameless candle. The design is beautiful and I will make more. I made it using wood and acrylic from SmokeyHills Designs.
  • K
    Kathy
    Rated 2 out of 5 stars
    2 years ago
    Lantern
    Pretty lantern. Very difficult to assemble, and when done, no way to put electric candle in it.
  • J
    Julia
    2 years ago
    Latern
    I enjoyed making this it is cute
  • J
    J.Williams
    Rated 4 out of 5 stars
    2 years ago
    Small lantern
    I do not have it done yet but it looks like it will be very nice....just expensive to produce especially if you do all three as a set.
