Special Fantasy Cloud Dragon in the Clouds Reversible Earrings
Made by Robert Danforth
More than is usual these Cloud Dragon earrings are shaped like the clouds in reversible pairs so they can be engraved on both sides. By tightly securing the material before cutting with the engrave on ignore. Carefully lift the pieces out, remove the masking, and run the engrave only, Then remove and replace flipped over in the opposite hole and run the engrave again without making any adjustments. As long as the material has not moved it will engrave in the same place.
7 min
0.12 x 1.25 x 1.38 in
    1x Blue Acrylic
