The Bigger Coaster
Made by xabbess
$6.99
$6.99
The Bigger Coaster holds even more than its smaller helper. Probably not advisable to use as a trivet for very hot things but perfect for holding more drinks and even some snacks. Sometimes, tabletop space is limited so having a coaster that can hold more than two things makes good sense. No more hassles with several coasters all over the table. Elegant, modern design. Great solution for anyone living in a smaller space. The base is laser cut from MDF, the second layer can be wood or acrylic in which you inlay pieces of 1/8” cork. You could even personalize one by engraving on the wood / acrylic.
Note: Cork print settings - Speed: 325 / Full Power / 1 Pass
1/8" Cork squares
1/8" Cork squares
0.25 x 8.0 x 12.0 in
cork
Rubber Cement
