Winter Wonderland Snowman With Winter Trees and Cardinals
A rustic and whimsical winter wonderland shelf sitter that will add warmth to your home. This easy laser cut design comes with both base options for 1/8 and 1/4 wood. Snowman and trees are 2 layers. Add a touch of red and your birds become cardinal.
30 min
2.67 x 13 x 9.53 in
- MSMalinda S.Verified ReviewerI do not recommend this productRated 2 out of 5 stars2 years agoSomething fell short
I just cut this design and found that the base plate pieces were totally wrong. The slots intended to insert the tree “trunks” are too long for the actual pieces. Also, there are two layers for the base, and the slots are different widths in each piece. The width (depth) of the base is narrower than the one in the photo so the assembly won’t be stable.
Since I have cut the top parts, I’ll design new base pieces. Of course you can’t adjust the size of the slots in the GFUI nor can you download the design to adjust it. But it shouldn’t be necessary. I’m disappointed!
