XL Happy Halloween Bat Sign - Bat Halloween Sign
Made by Crafting with Brenna
Take your Halloween Decor to the next level with this bat-themed, laser cut Halloween sign! This is a layered sign that can fit all on one GlowForge size sheet of material if it is sized to be 11" in diameter. You could also size it up to 18" without needing to use the Pro pass through slot. So you can use this laser cut sign however you'd like.
0.25 x 11 x 11 in
