Pumpkin Engraved Napkin Ring, Thanksgiving Napkin Ring
Made by Crafting with Brenna
This napkin ring is so cute to use for your Thanksgiving dinner place settings! It is quick and easy to make! This file uses slots. You'll need to measure your plywood with calipers prior to cutting in order to make sure the slot will fit. Currently, the slot is 0.125". You'll also need some glue to hold the pumpkin piece onto the front.
2.5 x 3 x 2.5 in
