Pumpkin Napkin Ring for Thanksgiving
Made by Crafting with Brenna
This file is perfect for making napkin rings for your Thanksgiving table. It does use slots. You'll need to use calipers to measure your plywood and make sure that it will fit in the slot. Currently, the slot is set up to be 0.125" but if your plywood is bigger, you'll need to ungroup the piece and make the slot larger.
2.5 x 3 x 2.5 in
